another fan question...
Old Aug 13, 2001 | 10:57 PM
Joe91Z28's Avatar
My primary fan doesn't kick on (or either does the secondary one for that matter). I can get both fans to work when grounding them with a test light, so I guess my relays and fan motors are fine. Is a faulty CTS the culprit for the primary fan problem?
Old Aug 13, 2001 | 11:43 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Could be a bad temp sensor. Happened to me. Both fans not running, but no blown fuses and the relays were good. Culprit was one of those sensors that screws into one of the heads.
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
