Disc Brake Rear end
Old Aug 15, 2001 | 05:47 PM
Jeasen's Avatar
Disc Brake Rear end
I just acquired an 86 TA parts car. It has a disc brake rear end. My 89 TA has drum brakes on the rear. Is changing to disc brakes worth the effort. The console is gone so no RPO codes. Any one know where they hide the build sheet? I would like to check the ratio!
Newbie 1989 Pontiac Trans Am w/305 TPI
Old Aug 15, 2001 | 07:19 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If you're going to the trouble f swapping a rear end into your car, you will no doubt be changing the fluid, as common sense would dictate; at that time you can count the teeth and then you would know for sure. RPO codes only tell you what came in the car, not what's in it now.
ICON Motorsports
Old Aug 15, 2001 | 07:29 PM
CamaroZ_85's Avatar
well you are one step ahead if you have an entire car at your disposal. off the top of my head, you'll need the rear (duh), the lines and calipers on it, and you'll also need to use the proportioning valve from the disc-rear car. i believe the master cylendars are the same, someone correct me if i'm wrong. i would just pop the tires off the old car and take the rear down w/ all the parts on it (just dont bang it around while it's out of the car since it will still have the brake stuff attached) then swap the valve and hook the fluid lines up. then you can do a rear brake job (if you wisely choose so) and familiarize yourself w/ the new system on your car. i just thought about the parking brake cables also; i would just disconnect it at the brake handle and hook it up to your car, just to make sure you have all the right parts working together. hope this helps...
85 Z28- 350, Comp 262, Edelbrock Performer intake, Edelbrock 600 cfm carb and Edelbrock cat back, Summit headers and vette servo
-JVC, Eclipse, Pioneer, MTX, Phoenix Gold, Planet Audio
[This message has been edited by CamaroZ_85 (edited August 15, 2001).]
Old Aug 15, 2001 | 07:32 PM
R.O.B.'s Avatar
My 86 TA with disc rears has a 2.77 ratio. Just something to give you a guess. By the way, I do believe the rear discs came with 16" wheels also, so be sure to check if your 15" wheels (if that is what you have that is) will work.
Rob
'86 TA 305 TPI
Gutted MAF, Ported Plenum
TB Bypass, Home made Cold Air Intake,
Edelbrock T.E.S.
48psi regulator, (Nickel method)
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
