cranks but no start?
Old May 9, 2005 | 01:43 PM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
Transmission: 5 Speed
ok i my car is cranking like and the starters engaging, i can even watch my oil pressure rise as i keep the starter goin...and i looked into my TB and saw fuel on the valves..so does that mean it has to be spark? if so how exactly do i test it?
also i was just haveing difficulties with starting it but it wouldnt even crank..i wiggled around the wire underneath my steering wheel and it started..then 5 hours later it cranking but not starting? could it be the starter enable relay or somthin to that effect?
Old May 9, 2005 | 02:32 PM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
another update...i have spark i hooked up my timing light to one of the plug wires n worked...also multimetered my battery n it checks out to 12.3?? so wat else could it be
Old May 9, 2005 | 11:16 PM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
When did it stop starting?
was there an event?
I guess that you mean the engine is turning over but not cranking.
Old May 10, 2005 | 12:17 AM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
k heres the update... i got spark, fuel, n the starter works...could it be that the timings off( but why would it all of a sudden change?), or do our cars have a camshaft sensor?
bryan623
Mar 22, 2021 06:43 PM
Caspar
Jun 19, 2016 11:19 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
