Modifying/porting vortecs for Comp XE274...
Old May 11, 2005 | 08:58 PM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
I did some searches and found that some people have been getting great results with vortecs and the Comp Xtreme Energy cams. The upgraded Scoggin Dickey heads have new springs, but how much would the stock vortec design benefit from some porting and what kind of porting should I have done. I have access to a guy who ports heads who will do it, I just want to know what to tell him. The current setup is a Goodwrench longblock with a Demon 625, shorty headers, Edelbrock RPM intake, 2200 stall.
Thanks for the help,
Matt
Old May 12, 2005 | 11:51 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
You also need to have the valve guides and a few other things machined for the extra lift.. that's the point I am at with my heads. I'm still trying to locate the exact amounts that need to be machined off and from where. If I find anything, I'll let ya know.
Old May 13, 2005 | 12:14 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
i am basically at the same point that tzfbird is at except i got the topline vortecs,and all the basics were done(trimmed guide bosses,tapped for screw in studs,pushrod holes drilled)they even had the intake ports smoothed on a jig for even gasket contact!
the only thing i'm going to do to mine,is remove some casting flash in a few of the intake ports,and maybe rough finish the intake ports while i'm there.the intakes are prety much as good as they get the way they come,there are a few places to touch up the exhaust ports,but the $ per gain ratio is not too good.you might get 15 or even 20 horses out ov it,but thats your call.
Eric
Old May 14, 2005 | 07:16 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
I'm not a pro porter/polisher, but I got great results from porting my vortecs. I went as far as I could in opening up the intake and exhaust ports.
I run the 268 HE, 1.6rr
Pac J
May 17, 2020 10:44 AM
no green
Jan 9, 2016 09:22 PM
