Adjusting rockers with new lifters?
Old Aug 15, 2001 | 11:37 PM
2QUIK6's Avatar
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
When adjusting rocker arm lash, the normal procedure would be to tighten the rocker lock nut when the cam is not engaging the lifter until you cannot twirl the pushrod by hand, then another 1/2 to 3/4 turn after that.
But with brand new lifters, the lifter is not pumped up any. What I have discovered is that I can do the procedure above, wait a little while, and the push rod becomes as loose as can be again.
Should I go back and re-adjust them after letting them sit for a while or turning the motor over a few times to pump the lifters up/down???
This is with hydrualic roller lifters.
Rob
High Performance & Party page
Pics of my rides past & present and recent party pics!
89 TTA #426 20th Anniversary turbo 3.8 bone stock
79 TA 6.6l - all original stock
94 Silverado Tuned Port Injected
87 Grand National- lil' ole V6, 12.40 @ 108 w/1.79 60'
95 Trans Am Conv.- LT1
Old Aug 16, 2001 | 12:01 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
No. Don't go back and re-tighten them or they will be too tight, the bleed down is normal.
Old Aug 16, 2001 | 12:05 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
No. After you get zero lash by spinning the pushrod until it stops then adjust the rocker 1/2 turn, you have now set the valve lash. That 1/2 turn is compressing the spring in the lifter. It will push back up after a while. Adjusting it farther puts too much valve lash in the lifter.
1/2 turn lash is all that's required. If you want to use a dial gauge you can set the lifter preload to .030" (the same as 1/2 turn).
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Aug 16, 2001 | 09:56 AM
2QUIK6's Avatar
There were a few that I did readjust. So should I go back and remove the rocker on those and let the lifter set for a while and then reinstall again without readjusting over time?
Old Aug 17, 2001 | 02:28 AM
JoelOl75's Avatar
Yes, lossen them up and let them sit awhile. Also don't tighten them until they don't spin and then 1/2 turn, more like a 'slight' drag with no up and down movement+1/2 turn.
Old Aug 17, 2001 | 09:05 AM
2QUIK6's Avatar
Thanks Joel.Since I have the intake off, somebody was telling to tighten them down just until the plunger on the lifter starts to depress, then just another 1/4 to 1/2 turn. Should about the same as the twirling pushrod method.
Old Aug 17, 2001 | 02:45 PM
Damon's Avatar
THey squeeze down easy when new becuase there's no oil in the adjustment chamber inside the lifter- only air and a light spring. First time you fire the motor and oi pressure comes up you will never be able to squeeze them down that easy again.
Air is compressible, oil is not.
tyeo098
Nov 30, 2015 06:27 PM
New2Chevy
Sep 28, 2015 12:35 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Stryker412
Sep 7, 2015 09:11 AM
dimented24x7
Sep 6, 2015 03:51 PM
