Help!!!! No Luck........
Old Aug 18, 2001 | 12:34 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
Well I removed the bent axle as per Vader and ede instructions. I tried finding an electric motor repair/rewind shop as per Vaders instructions but no such luck(at least around here). It was simple enough to get it off but.... I can't find a place to repair it or for that matter i can't even find a replacement one at the local salvage yard. How much do they usually run if i eventually run in to one? I remember seeing in a post that someone was selling a 9 bolt rear for parts. If anyone has 9 bolt axle shaft please let me know or if anyone has another suggestion do not hesistate to lety me know. Thanks.
88' IROC-Z, 350 TPI, 700-R4
Old Aug 18, 2001 | 12:59 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Call a machine shop and explain the situation, they should be able to give you a yes or no quote after they look at it.
Old Aug 18, 2001 | 01:05 PM
Car: 1988 IROC-Z
I have called many machine shops and axle shops. As soon as I said it was a BW they laughed and told me to use it as a paper weight. But thanks anyways.
Old Aug 18, 2001 | 01:10 PM
sunbitz's Avatar
Car: 91 RS Convertible
Engine: 305 TBI
Have you tried doing a cross reference at the junk yard?
At our local junk yard you tell them the part you're looking for and they give you a sheet of other cars that have the same parts.
Just a thought.
Old Aug 18, 2001 | 02:12 PM
Car: 1988 IROC-Z
thanks sunbitz. I'll give it a shot and see what develops. Hope this works.
Kandied91z
Jul 10, 2002 12:16 PM
