Squiking Sound on my Clutch??
Old Aug 19, 2001 | 11:46 PM
RS91's Avatar
What is this Squicking or Swirling sound comming from my clutch? It gets louder and faster as I accelerate. The only way to get rid of it is when I put a little pressure on the clutch. But as soon as I release it the sound goes back again....pls. Help...
thanks
Old Aug 20, 2001 | 05:13 AM
Pete 89 formula's Avatar
Sounds like your throw out bearing is bad.Thats the bearing that fits in your clutch fork and presses on your clutch fingers.
Old Aug 20, 2001 | 06:18 AM
Kiss_My_SS's Avatar
Master cylinder?
Kiss_My_SS
1992 Camaro RS/Heritage Package
1996 Impala SS
1985 Good ol' Chevy 4x4 Truck
Old Aug 20, 2001 | 07:44 AM
RS91's Avatar
If it is the bearing...What should I do or what should I replace...thanks..
Old Aug 20, 2001 | 07:54 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
If its squeaking, its either the TOB. or also check the pivot ball area on the clutch fork. Make sure you put lots of grease in that little pocket on the fork arm.
Either way, pull it out and replace everything while its out. (clutch, etc.)
Its not worth going back in there twice.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
devilschariot
Feb 25, 2016 03:08 AM
Drone358
Dec 10, 2015 08:16 PM
jtwoods4
Sep 3, 2015 05:39 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
