Rebuild?
Old May 19, 2005 | 08:44 PM
niceroc's Avatar
Car: 87 iroc
Engine: 454 .030 over
Transmission: th-350
Axle/Gears: 9 bolt
Rebuild?
if i was going to port my heads with new valves and seals and every thing would i need to rebuild my engine? ive heard that it will suck the piston rings right off the pistons? my motor has 110k miles
Old May 19, 2005 | 11:01 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I dont see any problem with it.
Old May 19, 2005 | 11:04 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Re: Rebuild?
Who the hell told you this? Some civic-driving teenage high school "tuner" kid?
Old May 20, 2005 | 05:54 AM
ede's Avatar
ede
rings getting sucked off the pistons happens all the time and ported heads only make it worse have you ever seen a piston, with or without rings on it? no way rings can get "sucked off the piston"
Old May 21, 2005 | 02:25 PM
niceroc's Avatar
Car: 87 iroc
Axle/Gears: 9 bolt
i didnt htink it could happen but i thought aboput it and ive seen piston rings fall into peices when the piston came out of the block and i could think if the valves leaked from the 110k miles and then you put new ones in and the pressure is restored it was possible i was asking becasue i didnt know i guess i wont ask anythign else
Old May 21, 2005 | 02:28 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
No no, continue to ask. It's the only way to learn.
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
hartsmike
Oct 2, 2015 07:11 AM
Derrick86
Oct 1, 2015 05:12 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
3.8TransAM
Sep 27, 2015 08:37 PM
