where is my voltage regulator
Old Aug 22, 2001 | 05:06 PM
Stormshadow GTA's Avatar
where is it and how much to replace,any specific brands i should get.
1987 Trans AM GTA
305 5SPD
Hypertech airfoil
gutted maf
kn filter
High Flow Cat,
3"Walker pipe
Dynomax Super turbo Muffler
TB Coolant bypass
Lubricated by Mobil 1 Tri-Synthetic
Old Aug 22, 2001 | 05:16 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's inside the alternator. It's about $20 or so; I think you can get a whole kit from Summit for about that much.
In regards to your other post, I doubt that anything of the kind is going on. I also doubt that your reguator is bad. What probably is happening, is that the brushes in the alternator are worn, and are no longer able to maintain their contact with teh slip rings. When that happens the alt stops charging.
You could either rebuild the alt yourself, or just get another, considering the kind of trouble people always seem to have with rebuilt onew, you are probably better off to do it yourself, perhaps with the Summit kit or with parts you can get from your local parts store.
ICON Motorsports
Old Aug 22, 2001 | 05:33 PM
thanks for the info but i just replaced the alternator and im haven the same problem.could it be my battery
1987 Trans AM GTA
305 5SPD
Hypertech airfoil
gutted maf
kn filter
High Flow Cat,
3"Walker pipe
TB Coolant bypass
Mark_ZZ3
May 24, 2018 01:02 PM
gixxer92
May 18, 2017 11:20 AM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
Dragonsys
Sep 25, 2015 03:51 PM
