EGR Help...Please
Old Aug 22, 2001 | 10:33 PM
BlackBird305's Avatar
EGR Help...Please
well it was time for inspection and my EGR was bad (been that way since i bought the car) so i put a new one in and now between 40mph and 50 mph it doesn't seem to run as smooth...its a little rough almost like detenation or a fouled plug but it must not be cuz it only does it between 40-50...i know EGR is only active at certain part throttle settings...is this just the egr doing its job?...thanks guys
91 Pontiac Firebird...305 TBI
black, t-tops, auto
K&N 14x3 open element flat base air cleaner, 3 inch high flow cat, 3 cat-back into a flowmaster 80 series, IAT Resistor, ultimate TBI mods, 160 stat Hypertech Thermomaster Chip, TC lock-up switch, SLP Torsen Posi w/Richmond 3.73's, removed rear seats, Spohn LCA relocation brackets...SOON TO COME...headers and y-pipe, Nitto Extreme Drag Radials, LT1 Cam, Edelbrock Performer manifold
Old Aug 23, 2001 | 09:24 AM
anyone???
Old Aug 23, 2001 | 10:26 AM
BARRY 91T/A's Avatar
did you have to disconnect you negative battery cable,to clear your computer code,if you did alot of times the car will run rough up to 20 miles while it resets itself,,just a thought,,,have done it several time with my 91 t/a 305 tpi
Old Aug 23, 2001 | 11:12 AM
totally forgot about that...i'll give it a try
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
meeklay812
Oct 1, 2015 03:46 PM
