feels weak after intake/cam/exhaust
Old Aug 24, 2001 | 10:06 PM
rezinn's Avatar
I recently put a super ram intake, edelbrock base, lt4 cam and 1.6 roller rockers, ported aluminum l98 heads, edelbrock coated TES on, and the car feels really weak. I haven't driven it far at all, because the coolant temp sensor in the head isn't working and I really don't want to screw anything up. I also changed over to serpentine from v-belt.
Now, I can hear a vacuum leak from the passenger side runner, would this cause bad acceleration? I know its causing my sloppy idle. It will die out occasionally if I am stopped, Im going to tear the intake off tomorrow to fix that.
One more thing, how much loping(if any) should I see from this cam? It is NOT the HOT cam, just a stock LT4 cam with 1.6 ratio rockers. It feels like there is much more cam in there at idle. Im guessing that the vacuum leak is causing this, though.
Okay, last thing here, really.. Should I be looking into a new chip with these mods? Will fuel starvation be a factor at all? My entire fuel system is stock, except afpr set at stock pressure.
[This message has been edited by rezinn (edited August 24, 2001).]
Old Aug 24, 2001 | 10:14 PM
Guest
Guest
Posts: n/a
Id definitely fix the leak, that can screw up an FI car pretty good.
Try advancing the timing a few degrees, it should help performance.
Old Aug 24, 2001 | 10:18 PM
rezinn's Avatar
Thanks max, I probably retarded it too much after I heard it knocking. Can't wait to take that super ram off :\
Falcon50
Aug 22, 2020 03:26 PM
Ed1LE
Sep 30, 2018 09:14 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
lanceflame44
Sep 25, 2015 12:28 PM
