Broken Up Cat = HP Loss ?
Old Aug 25, 2001 | 02:11 PM
GTA88's Avatar
As far as I know , my cat is NOT clogged, but, the insides of my cat rattle a lot when you bang on the bottom of it. Does this restrict flow or open up flow ? Is it moving out of the way of the exhaust flow, or into the way ??? I have noticed the car seems less quick since I bought it 3 years ago, but I thought maybe I was just getting used to a fast car.
88 GTA 5.7 TPI Charcoal Grey Bone Stock except for loose muffler which makes it a bit louder than normal.
Old Aug 25, 2001 | 03:00 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Yes, it can restrict flow, usually the pieces will turn sidways and block the exit pipe.
They can also come completly out of the cat and clog the muffler.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Aug 25, 2001 | 06:44 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Yes it can restrict. The ceramic honeycomb matrix has broken. I discovered this when I replaced mine. One portion had come lose and turned sideways so instead of being aligned to the flow it became a big restriction.
sheachopper
Jul 31, 2019 11:27 AM
no green
Jan 9, 2016 09:22 PM
