TFS Gen 1 owners question....
Old Aug 26, 2001 | 11:03 PM
92 RSS's Avatar
Car: 1992 Camaro RS
Engine: 5.7
What size pushrods are you running? (intake and exhaust)
Thanks!!
92 RS, 350, Street & Performance MPFI, TFS heads, Stock crank and rods, Fordged flat tops,
Crane Rollers,
MSD Digital 6 Plus, 22lb injectors,
ZZ3 cam, Edelbrock Headers 1 5/8, 3" Exhaust,
Hi Flow 3" Cat, stock T-5,
stock rear 3.08, koni yellow adjustable front, twin turbo glass hood, T-tops, Auto Meter Ultra Lite Series 2 5/8 gauges, Teal Green
Old Aug 27, 2001 | 02:23 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
I'm running stock length pushrods for a flat cam, since i have a flat cam... Your 92 has a roller so i'd guess the stock roller pushrods would be the choice. I assume you are talking about the 23 degrees. Either way you should check the geometry, but as long as you havn't milled the deck or heads it should be stock. I had .023" taken off my deck and my geometry is still a-ok, so I guess they may be longer... Now i'm confused. I guess calling up Summit or trick flow would be you're best bet, or get an adjustable pushrod to check the length.
The twisted wedge require different special lengths.
eightsixseven
Dec 16, 2024 01:50 PM
cam-mike
Aug 24, 2015 07:23 AM
theurge
Aug 21, 2015 12:46 PM
