Loose steering colum! HELP!!!
Old Aug 26, 2001 | 11:36 PM
Greg Kuhlmann's Avatar
I have a 87 T/A. THe whole steering colum is loose, and you a 1/2 inch play all around.. how do i fix this? what all has to be took off/how do i get to it? THANKS
Old Aug 26, 2001 | 11:59 PM
Corry's Avatar
Car: 1987 Trans Am
Axle/Gears: 10 Bolt SLP Torsen, 3.73 ratio
there's actually a tech article about tightening the steering column. If you run into snags, Vader has some really sweet blow up diagrams of the steering column. I personally had to take all the electronics stuff outta the inside of the colum, and remove the tilt wheel stuff and get down to I think they were 4 reverse torx screws (reverse torx screws, stil the star chape, but the screw head looked like a torx bit, had to get a socet to fit around it). I pulled them out, and put *plenty* of locktite on there...so much, those screws will probably never come out...unless locktite rots over time then put it all back togather. To simplify things, I pulled out the extra screws and starter mechanism, and totally pulled the column so I could work inside.
Good luck
Corry
Old Aug 27, 2001 | 02:42 AM
Omar's Avatar
If you have tilt steering, you will also need a pivot pin remover from Mac Tools or Snap On, or you will have to fab one up.
1989 IROC-Z 5.7L
NOS 5151 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Ed1LE
Sep 30, 2018 09:14 AM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Night rider327
Sep 25, 2015 04:19 AM
