LG4 + L98 parts
Old May 31, 2005 | 01:07 PM
jovial86's Avatar
Car: 1986 Pontiac Firebird
Engine: 1991 305 TBI
Transmission: Th700-R4
LG4 + L98 parts
I was considering upping the measly LG4 with better flowing L98 heads and bigger L98 cam and some non-AIR headers. My question was: will the L98 heads and cam feel comfortable in my LG4? The LG4 is in a '90 Firebird, but it's an '85 Trans Am LG4. What about the cam? I'm not really looking for a burner motor, just something to scoot me along a little faster. If this combo is to work, how would I tune the carb?
Old May 31, 2005 | 03:46 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I wouldn't bother getting a different set of heads. Your current heads with 1.94" intake valves and basic port clean-up will flow as well as the L98 heads. Plus, the L98 heads will have the center two bolts at a different angle than your intake manifold, and will need to be shaved to bring the chamber size down to 305 size.
Most any mild computer-compatible cam should do.
What have you done for exhaust? Air cleaner? Those are restrictions that should be addressed before any thought is given to cam or heads.
Old May 31, 2005 | 04:15 PM
jovial86's Avatar
For exhaust i have a 2.75" mendrel bent single through with a cat and flowmaster muffler, im going to adda shorties later on. For air, I'm running open element with a summit (K&N rip-off) X-filter.
I was wondering about hte L98 cam (chose it because i got it for free) because it wouild be from a next gen block (86+), would that cause problems?
Thanks,
-Matt
Old May 31, 2005 | 04:33 PM
five7kid's Avatar
Yes, the later cams are factory roller lifter types. Although they can be made to work in non-factory roller blocks, it isn't pretty - and probably not worth the hassle.
Old May 31, 2005 | 04:36 PM
jovial86's Avatar
Back to the drawing board then, I suppose
Old Jun 1, 2005 | 08:28 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
First do the exhaust - you will be surprised how much power you will pick up. Then a dual snorkel intake, EGR intake manifold. underdrive pulleys, electric fans..... all bolt ons that will give you 210hp+.
Old Jun 1, 2005 | 10:43 AM
five7kid's Avatar
The '90 should have had electric fan, unless they swapped over the engine driven from the '85.
lt500r55
Sep 1, 2021 01:30 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
