Please help! horribly loud metal on metal ping
Old May 31, 2005 | 10:31 PM
DarknessZ28's Avatar
Car: 1985 Camaro Z28
Engine: lg4
Hi im new to the board and i have a 85 camaro with an lg4 engine, I was driving like an idiot yesterday and all of a sudden my engine started pinging real loud. So I changed the oil and pulled the valve covers and looked at all of the lifters and none of them are bent, so i will be pulling the heads tomarrow and i was wondering before i go through all that work, if it could be something else other than the valves? The ping speeds up when giving the engine throttle and sometimes it is erratic at idle any advice would be appreciated
Old May 31, 2005 | 11:16 PM
violentgod1's Avatar
Car: 1989 RS
Engine: 305 ci v8 LO3
Transmission: WC T5
i have more like a knock in my engine that sounds like them symptoms and i heard it could be the flexplate so im pulling the tranny this week to replace it. Check that out to see if ya got a crack or not.
Old Jun 1, 2005 | 11:59 AM
sellmanb's Avatar
Car: '86 Berlinetta
dont pull the heads just yet. It is very unlikely that you bent a valve w/o being able to see it when pulling the valve covers.
First... what is your oil pressure now?
If it's normal, then do you have headers? If so, check your header gaskets.
If not:
Firstly take a mechanic's stethescope (or a piece of heater hose) and listen around the motor to determine approximately where the sound is coming from.
Take your flexplate inspection plate off and make sure that the flexplate is not broken or anything of that sort.
I'd pull out all of the pushrods and roll them on something that you KNOW is perfectly flat, like a glass table or something. If any are bent, replace them.
Make sure that none of your rocker arm studs are lifting out.
Take your intake off and check the lifters
Make sure none of your rocker arms are mis-shapen or anything like that.
Note: Do these one at a time, obviously if you can find with the heater hose or stethescope where the sound is, then you dont have to take the intake off and such.
Reply back to the thread with details
Old Jun 1, 2005 | 08:44 PM
Engine: lg4
Ok thanks guys ill give your suggestions a shot and get back to u with the results
Old Jun 1, 2005 | 09:01 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
Sometimes a small piece of hardware will drop down your intake and get lodged in the piston dome and make the noise you're describing.
If that happened, it would most likely be a piece from your carb. Check your carb and see if all the screws are all there.
Have you done any work on your car with the air cleaner removed lately?
MrPackstin
Oct 25, 2017 08:09 PM
loud91rs
Oct 5, 2015 10:05 PM
Numbah-1
Oct 2, 2015 08:27 AM
sjorgens
Oct 1, 2015 07:54 PM
