testing my ecm by using a known good one?
Old Jun 1, 2005 | 07:58 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
Where could I come across a ECM for my 86 305 tpi so i could just swap it out real quick and test it to see if its the ecm wigging out? Would a junkyard let me do that if i did it right there on the spot with them watching?? thanks!
Old Jun 1, 2005 | 08:08 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
worth a shot, worse they could tell you is no.
Old Jun 3, 2005 | 02:16 PM
Damon's Avatar
They won't take stuff back, especially electronic parts. They shouldn't charge you more than $20-25 for a good used one. You can buy a remanufactured new one for about $60 from most parts stores.
In either case you'll need to swap your existing chip into the new ECM before you install it.
Remember that the same ECM used in the Camaro was used in a ZILLION other GM cars- Buick Regals, Pontiac Grand Ams, Chevy Cavaliers, etc, etc. It's the same ECM but with different chips in it- that's why you always need to swap your chip over.
Salvage yards have something called a "Hollander Interchange Manual" that lets them cross-reference across all different makes and models. Don't be surprised if the ECM they hand across the counter got yanked out of a GM car other than a Camaro! Swap your chip in and you'll be good to go.
Old Jun 3, 2005 | 10:29 PM
Update on my car is this. Turns out the ECM wasn't bad, I had the part's guys were I work order me one and I tired it and it didn't fix my problem. I then had my dad, who is a electronic technician come check it out cause I was at wits end, and he found all sorts of wiring messed up from an aftermarket alarm system, and also the new fuel pump relay I had was bad. Got it all wired back up right like it was originally, threw a new fuel pump relay in it, and now purrs like a kitten! WOOOT!!! Thanks for your help though guys!!
Old Jun 3, 2005 | 11:49 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
that great news. alarms can cuase many problems when they go south.
specialized
Jun 18, 2022 09:26 AM
Jae992
Aug 27, 2015 09:07 AM
ezobens
Aug 19, 2015 10:29 PM
ChevyZ71
Aug 13, 2015 07:30 AM
