it makes what blown up car movie sound
Old Aug 31, 2001 | 01:50 AM
speedfreaker's Avatar
when i shut off my car it makes a kurk kurk sound kinda like in the movies when u see the junk cars but while its running it runs fine 4 a 305 anywayz anyone might have an idea??
CHRIS
1983 firebird transam
Old Aug 31, 2001 | 02:26 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Sounds to me like your car is dieseling. Try using higher octane gas. If this doesnt fix it, you could be running rich and causing carbon deposits in the cylinders.
1983 Firebird
TH700R4 Auto
Small Block 400
LG4 ECM, Intake, Carb, Distributor, etc.
Soon to be non-computer.
Clarion Head Unit 45X4
2 Pioneer 400W 12" Subs
Third Gen Performance
"A four cylinder is half an engine."
"Ponies can run, but birds can fly..."
Old Aug 31, 2001 | 06:59 AM
West Coast GTA Man's Avatar
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
Could it be timing?? Doesn't hurt to check it.
Later
Mike
Check out My Car Pics http://albums.photo.epson.com/j/Albu...667&a=13599419
Gran Turismo Americano "The Ultimate Firebird"
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber) & AC Delco Rapid Fire Plugs
Old Aug 31, 2001 | 07:35 AM
Damon's Avatar
Also check your idle speed. If it's idling at 1000-1100 RPM then you will get dieseling as described above.
If you ARE idling too fast don't just crank the idle speed screw down, look for vacuum leaks first. That vintage of cars had MILES of vacuum line under the hood and any one of them (or all of them) could be leaking. The gasket under the carb could be leaking, too. Spray around with carb cleaner to find external vacuum leaks. Pinch off or disconnect and plug vacuum lines to find other vacuum leaks like from the trans. modulator diaphragm or from a diaphragm behind the dash in the HVAC system. Vacuum leaks are responsible for at least 1/2 of the wierd idling/stalling/dieseling and drivability problems with these cars.
Ghettobird52
Jul 5, 2024 11:18 PM
colton_carlson
Mar 8, 2019 12:21 PM
midias
Aug 22, 2015 01:42 AM
mustangman65_79
Aug 8, 2015 12:07 PM
gwade12
Aug 8, 2015 08:17 AM
