TPI vs TBI fuel pump
Car: 91 RS
Engine: 305 TBI
I have heard that a TPI fuel pump is better than a TBI fuel pump; is that true? If so, will the TPI pump match up to the TBI sending unit? Thanks.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The TPI pump is a high pressure unit and will supply 40+ psi of fuel. The TBI is a low pressure system and will run no more than 12 to 15 PSI. If you are swapping pumps go with a TPI pump or another form of high flow unit. I would look into a walbro pump since I don't trust GM pumps.
Car: '90 RS
Engine: 377 LSX
Originally posted by Cole
Do you know if the sending units are the same?
Car: 91 RS
Engine: 305 TBI
Yep i just replaced the factory pump with a tpi pump. About the sending units, the tpi does not have a return line the the tbi do. Also after i replaced the pump, i can now hear the pump, does this mean anything or is that normal?
Car: '90 RS
Engine: 377 LSX
Originally posted by 8Mike9
You're running the TPI pump on your TBI? Didn't know the regulator in the TB would hold that much pressure.
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
