fixed oil leak, overheating still somewat a prollem
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
ok, as i said i fixed the oil cooler. no more leak. yessss. well my oil pressure is around 29 at an idle when the car is hot. is that ok? it comes from the stock oil pressure guide. also. my fans arent turning on. i was told to check them my running them live to see if its the motor or the switches. is this true? if its the switches, which one are they? also i am slowy replacing all the easy coolant thyngs such as the thremostat and the water outlet gasket. wat r some other cheap thyngs i could do. thanks.
Navy8125
Aug 21, 2015 09:32 AM
