ignition question (can you have too much?)
Old Sep 1, 2001 | 09:10 AM
speedlvr's Avatar
Ok, in my switch from tbi to carb I have installed the RPM intake, throttle bracket, 750cfm Edelbrock (cables not hooked up yet), MSD Pro Billet HEI distributor #8365 (coil in cap, ready to run). Left to do: AFPR, hook up cables (throttle and detent) to carb - I am going to rig up something with parts off my throttle body linkage. One more thing and that's what my question is about. I have an MSD 6a ignition box and am wondering if installing it will benefit my setup at all. The reason I wonder about this is because the distributor I have has a high energy module that produces 50% more current than stock distributor modules and produces hi energy spark up to 9000rpm. The pro billet produces 100mj of spark to 4000rpm and the 6A produces 105 to 115mj to 3000rpm. Is the 6A going to be overshadowed by the pro billet distributor?
Old Sep 1, 2001 | 09:41 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
naw short of burning the plug gaps wider and the possibility of the plugwires breaking down, there is no negative aspects of too much secondary ignition power.
The high output module is much more likely to continue working under the requirements of the msd than a factory one.
[This message has been edited by jcb999 (edited September 01, 2001).]
Old Sep 1, 2001 | 10:38 AM
speedlvr's Avatar
I'm assuming you're saying there's no need to use the MSD6A along with the MSD pro billet distributor. If I can keep things simpler and not even use the box if it really won't benefit anything, that is what I want to do.
Old Sep 1, 2001 | 04:05 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
well, the distributor (and specifically the module) should be considered the starting point of the ignition event. If it is not good and repeatable, the MSD won't help much. But, when an msd is combined with a good quality module, coil and plug wires, you have a complete high quality primary and secondary ignition. So, yes, use both.
Old Sep 1, 2001 | 05:35 PM
speedlvr's Avatar
Will do. Thanks.
BRoss99
Aug 10, 2025 05:08 PM
Caspar
Jun 19, 2016 11:19 PM
theurge
Aug 21, 2015 12:46 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
