LS1 rockers?
LS1 rockers?
Will the roller rockers off a LS1 fit out small blocks (92)?
Jeremy
WE WILL MISS YOU #3
92 Z conv
5-spd B&M shifter
home-made ram air, air foil, headers, no cat, TB bypass, kevlar pads, slotted rotors, BMR panhard, alston SFC, 3.42's, Edelbrock STB, 350 in the works
Jeremy
WE WILL MISS YOU #3
92 Z conv
5-spd B&M shifter
Car: 4
Engine: 6
Transmission: 5
The lt1 rockers are the same as normal small block rockers except that they are self-aligning rockers. Some of the L98 rockers are self-aligning so if yours are the same thing you can use them but the stock stamp steel rockers are 1:5 ratio so you would not get any performance or any other atvantages. Hope I have helped some.
I am just looking into a set of rollers and seeing what my options are.
Jeremy
WE WILL MISS YOU #3
92 Z conv
5-spd B&M shifter
Jeremy
WE WILL MISS YOU #3
92 Z conv
5-spd B&M shifter
