Where to hook up distributor advance?
Old Jun 9, 2005 | 02:04 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
i am switching from tbi to carb and i am trying to get the vacuum hooked up on the dist. but i am unsure of where to hook it up. there is no where to hook it up on the manifold, i am using an edelbrock perfromer rpm manifold and carb. Does it hook up to the carb? I tried a search and everyting says to hook up to the manifold.
Old Jun 10, 2005 | 07:05 AM
ede's Avatar
ede
connect it to the carb, i'd try a source below the throttle blades first. if you don't like that move it to above.
Old Jun 10, 2005 | 07:15 AM
toofast's Avatar
If you are looking at the frount of the carb it should be the vac port on the right or the carb adjustment screws. You want vac at idel ,off win you give it the gas.
GTAman
Jul 3, 2024 07:29 PM
Jorlain
Oct 8, 2015 01:57 AM
86CamaroDan
Sep 29, 2015 10:08 PM
angel2794
Sep 8, 2015 06:22 PM
