Going from FI to carb
Old Jun 11, 2005 | 10:13 PM
Iroc383Kid's Avatar
Car: 1989 Iroc
Engine: 383 Stroker
Transmission: 700-r4
I had a TPI on my motor but was not happy with it and want to go with a cab, I was wondering what i can remove from the harness and other things not needed. Also what will i do for ignition.
Old Jun 11, 2005 | 10:16 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Make sure the TPI is shipped straight to my house. LOL.
You can remove the ECM harness as well as the unused sensors, etc. You will need to change the throttle cable and TV cable. You will need a regular vacuum advance distributer too. You didn't say if you had an AUTO but if you do you will need a TCC lockup kit. Another thing you will need is a bypass style fuel pressure regulator to lower the fuel pressure down to the 3-5 required for the carb without deadheading and burning up the pump.
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
