Oil sender?
Old Jun 14, 2005 | 12:19 PM
atryko's Avatar
Car: 89 firebird
Engine: LO3 TBI 305
Transmission: 700R4 auto
Oil sender?
I have a '89 firebird with the TBI 305. I believe my oil sender unit is toast. (0 psi on the factory gauge some of the time, with no ticking, clacking, or knocking) Could someone point me in the right direction as to where I can get the part? And where exactly the part is on the car?
Old Jun 14, 2005 | 01:19 PM
ede's Avatar
ede
any parts store, either on the rear china wall or above the oil filter
Old Jun 14, 2005 | 01:29 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Dont do what i did (waste 2 hours trying to get it off) They sale a oil pressure socket. Make sure you get that. You might need to get 2 of them. One bigger than the other. Also get the deep kind and put some teflon tape on the treds of the unit. Good luck
Any parts store will have what you need
Old Jun 25, 2005 | 11:23 PM
atryko's Avatar
Car: 89 firebird
Engine: LO3 TBI 305
What would I need the teflon tape for? Sorry, I'm not the best wrench-turner.
Old Jun 26, 2005 | 12:48 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
They teflon tape is to seal the threds from leaking oil.You sure dont want an oil leak.
Old Jun 26, 2005 | 01:47 AM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
indeed. but do not put to much teflon tape on it since the threads do need to make a metal to metal contact. else it will not ground the thing to the bloc causeing it to act funny (at least that is what it did with my single wire one.
Old Jun 26, 2005 | 12:55 PM
atryko's Avatar
Car: 89 firebird
Engine: LO3 TBI 305
Fixed the problem.
Well, I picked up the sender, socket, & some teflon tape. Changed it out during my oil change. Did take a while to find a wrench to get the original off. (I could only get the socket to fit the new sender) But, I ended up getting the old one off with a
1-1/4" open end wrench pretty easily. (The new one is a 1-1/16" socket) Just wanted to add an ending to this thread that so many threads lack at times, and also say thanks to those who helped!
jrdturbo
Mar 31, 2016 02:58 PM
NZKnight
Oct 15, 2015 02:47 PM
skinny z
Oct 5, 2015 06:23 PM
CatmanFS
Sep 19, 2015 09:00 AM
