Sbc Bolt Sizes Anyone???
Car: 94 Camaro
Engine: 383 Stroker
Does anyone know or have a link to all the bolt sizes for a small block chevy?
I know the harmonic damper is 7/16 - 20 x 2.25 and the cam bolts are 5/16 - 18 x 3/4 and the exhaust manifold bolts are 3/8 - 16 x 3/4.
Anyone know the sizes of the 3 different head bolts, main bolts 4 or 2 bolt, oil pan bolts, oil pump bolt (I think this one is 7/16 - 14 x 2.25 but im not sure), intake manifold, valve cover, thermostat housing, distributor, timing cover, water pump, all accessories (alternator, pulleys, etc.)
I think this would be very helpful to anyone building a sbc. Too late ive already bought all of my bolts in a kit or i wouldve definitely taken advantage of this. I guess it would be easiest to just start a running list.
Harmonic damper = 7/16 - 20 x 2.25
Cam bolts = 5/16 - 18 x 3/4
Exhaust manifold bolts = 3/8 - 16 x 3/4
Oil pump = 7/16 - 14 x 2.25
the head and main cap bolts are specialized and can use hardwear store bolts. the oil pump bolt length is very critical. oil pan, valve covers, and timing cover are 1/4-20x3/4" and oil pan also has four 5/16-18x3/4" bolts. you much have the shortest manifold gm ever put on an engine. i'd guess the length to be more like 1 1/2". t stat is 3/6-16 and length would depend on what hat you had. intake would be 3/8-16x1 1/4"
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
<table><tr><td>Coil Bracket:<td>5/16-18 x 9/16
<tr><td>Distributor Hold-down:<td>3/8-16 x 1/2
<tr><td>Fuel Pump:<td>3/8-16 x 1 1/4
<tr><td>Fuel Pump Plate:<td>1/4-20 x 1/2
<tr><td>Intake:<td>3/8-16 x 1
<tr><td>Motor Mounts:<td>3/8-16 x 3/4
<tr><td>Oil Pan:<td>1/4-20 x 1/2, 5/16-18 x 9/16
<tr><td>Timing cover:<td>1/4-20 x 1/2
<tr><td>Valve Covers (perimeter):<td>1/4-20 x 1/2
<tr><td>Water Neck:<td>3/8-16 x 1, 3/8-16 x 2
<tr><td>Water Pump:<td>3/8-16 x 2, 3/8-16 x 2 1/2</table>
Car: 94 Camaro
Engine: 383 Stroker
Same here. Im trying to start a list so that it would be easier for someone just starting out to do this instead of spending a ton of money for bolts from jegs or using old ones.
evilstuie
Jan 9, 2020 08:29 PM
toronto formula
Nov 10, 2015 06:17 AM
knight72
Aug 10, 2015 09:32 PM
