Backfiring through carb, please help
Old Jun 18, 2005 | 11:53 AM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
I just completed my TBi to carb swap, and i got her up and running. When i have the timing set at 0 it pops through the carb when i rev it up. But when i advance it to about 8 degrees it stops doing it. That is running about 3 PSI and ive tried other psi also but it does the same thing. What could cause this? Am i just gonna have to leave it at 8 degrees?
Old Jun 18, 2005 | 12:07 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
8 degrees initial timing, set with the vacuum advance disconnected, is a good starting point. 8-12 degrees is typical.
Fuel pressure does not affect carb performance (until there is too little to keep the bowl full or too much for the needle & seat to shut off).
Old Jun 18, 2005 | 12:30 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Ok, i just found out that i had to dissconnect the vacuum advance. I have been setting the timing with it hooked up, so ill will set it again. Also i am gonna adjust the carb, could this also cause backfireing?
Old Jun 18, 2005 | 12:38 PM
five7kid's Avatar
Adjusting the idle mixture screws probably won't have any effect on that.
Old Jun 18, 2005 | 01:38 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Well, i just got done messing with it again. I had the timing at 8 degrees and still backfired, this time it shot a big flame and kill the engine. It seems like it only does it with the car at a idle, then mash the gas all at once, and it happens. Should i just try to advance it some more?
2012sergen11
Oct 13, 2015 07:38 PM
85 Jimmy
Sep 30, 2015 07:56 AM
Damon
Sep 26, 2015 04:29 PM
lanceflame44
Sep 25, 2015 12:28 PM
RedLeader289
Sep 23, 2015 06:50 AM
