ZZ4 Cylinder Head Flow Numbers
Old Jun 19, 2005 | 11:07 PM
pellmanm's Avatar
Car: 1989 GTA
Engine: 383 Fuel Injected
Transmission: Pro-Street 700-R4 by Pro-built
Axle/Gears: Moser 12 bolt w/posi
Can anyone find the flow numbers for the cylinder heads that are used on the ZZ4? According to Sallee Chevrolet, if you put a if you take the 355 HP ZZ4, and put in an LT-4 Hotcam w/1.6 rockers, you upgrade the output to 395 horsepower and 425 pounds of torque. So i am wondering what would be the difference if i used Edelbrock Performer cylinder heads. Edelbrock has the flow numbers for their heads on their website, but i can't find the flow numbers anywhere for the heads used on the ZZ4?
Old Jun 19, 2005 | 11:35 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
http://www.chevyhiperformance.com/te...98/index4.html
IIRC they're the L98 heads, shown in the link article.
You can get a GMPP porting option on those, which is supposedly pretty good.
I have a link somewhere for that data, but I'll have to dig around to locate it. Maybe someone else has it more readily at hand.
Edit:
https://www.thirdgen.org/techbb2/sho...hreadid=236508
https://www.thirdgen.org/techbb2/sho...hreadid=262473
Old Jun 20, 2005 | 10:41 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Flowing only 199cfm at 0.600 lift, it would be almost impossible to get 395hp out of ZZ4 heads and .525: lift - you would have to run right at the maximum to do it......
Old Jun 20, 2005 | 09:39 PM
pellmanm's Avatar
Car: 1989 GTA
The ZZ4 with its base cam makes 355 HP, according to Sallee Chevrolet, installing the larger LT-4 HotCam adds 40 HP, so i am guessing if i had the Edelbrock heads on with the LT-4 Hotcam, i should see just over 400 HP?
1992 Trans Am
May 10, 2023 07:19 PM
lt500r55
Sep 1, 2021 01:30 PM
Steve78LT
Feb 24, 2016 12:15 AM
Mickeyruder
Sep 2, 2015 02:45 PM
NinjaNife
Aug 23, 2015 11:49 AM
