changing bearings
Old Jun 22, 2005 | 09:48 AM
theboilermaker's Avatar
Car: 87 camaro sc
Engine: 357 w/ cc qjet
Transmission: 700 r4
changing bearings
I'm am changing the bearings in my 87 305; does anyone have any hints or tips to make this go smoothly? Do I need to pull the motor? thanks
Old Jun 22, 2005 | 09:49 AM
ede's Avatar
ede
yes pull the engine. why you only changing the bearings?
Old Jun 22, 2005 | 12:33 PM
toofast's Avatar
You can do it take your time one at a time. Go to the hardware store buy a plastic puddey knif grind it down to fit the top half of main bearing and tap the top half out.Be sure to change the oil pump .My two cents Later
Old Jun 22, 2005 | 07:06 PM
Car: 87 camaro sc
I have no reason to poor money into a 305 when I have a 350 that I am building up. Since that wont be ready for another couple months I need to change bearings to get the maro back on the road. thanks for the tips on pulling the bearings. I was hoping they were easy to tap out!! I assume the old ones are easier to get out than the new ones to get in.
Old Jun 22, 2005 | 07:17 PM
TWICEtheRICE's Avatar
Car: 91' Pontiac Firebird
Engine: 388 ci Small block CHEVY (4.060x3.75), Dart Iron Eagle Platinum 200cc, Performer intake, 454 TBI, Long Tubes, True Dual 3" GPs
Transmission: 700R4, B&M, Governer Recal, 20,000 GVW cooler
If for a couple months, just slap those in and go!
For longevity:
You should really get new main bolts and rod bolts.
You should plastiguage all the bearings.
You should replace the oil pump.
Engine work is like surgery, be very clean.
You have a lot of work ahead of you to get to the bearings, so good luck.
redmaroz
Apr 25, 2017 07:14 AM
Kevin91Z
Southern California Area
Sep 16, 2015 03:00 PM
gixxer92
Sep 1, 2015 04:32 PM
theshackle
Aug 31, 2015 10:47 AM
red90IROCls1
Aug 25, 2015 06:56 AM
