Need to replace charcoal canister, but how?
Old Jun 24, 2005 | 09:34 PM
Supermann's Avatar
Car: '86 Camaro, '85 Z28, '92 Firebird
Engine: LB8 2.8, LG4 5.0, LO3 5.0
Transmission: TH-700R4, T-5, TH-700R4
Axle/Gears: 3.42s, 3.23s, 2.73s
The stupid deleware emissions tests include a visual inspection for a charcoal canister, and my new '85 z28 doesn't have one in it. Looks like the previous owner just took it out and plugged the line going to the fuel tank, and I don't know where else the vacuum lines were running to on the carb. Does anyone have pictures of a charcoal canister setup on a carburated car, or know where everything hooks up too? And I hope once this is replaced it will help it pass the sniffer test because it failed that too with way too much carbon monoxide. Will having the canister help pass that test?
Old Jun 24, 2005 | 10:34 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
I'm about 100% positive that the charcoal canister only reduces hydrocarbons from fuel vapors in the gas tank. Too much CO may be attributed to an aging cat or bad AFR mix, but I'm not too certain on this one...
Old Jun 26, 2005 | 10:00 PM
Supermann's Avatar
well, the cat might be the problem since apparently it was already gutted, but I was hoping to find some other way of correcting the CO levels without relpacing that. But they still check for the canister and I really need to know where the vacuum lines run to on the engine.
Old Jun 27, 2005 | 04:42 AM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
Here you go:
Use that unless you have a Canadian car... if so, use this:
EDIT: By the way, if you know where to find a brand new charcoal canister other than the dealer, let me know. I need a new one as well.
Old Jun 27, 2005 | 08:35 AM
KintaroOe's Avatar
Car: '91 bird '87 Z28 '86 T/A
Engine: LO3 LG4(ls1 in works) 350
Transmission: 700R in all
Axle/Gears: wimpy 10 bolts
i use to remember on the fiero forums, of someone replacing the fuel canister with a v8 juice can or something similar and putting (charcoal??) in it through a hole big enough to attach hoses to... its just an idea though. just my
Old Jun 27, 2005 | 09:33 AM
kevinc's Avatar
Car: 1982 Z28
I got mine from the local NAPA shop after digging up part #s on napaonline.com for $45 or so.
Old Jun 27, 2005 | 07:01 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Hmmm...I forgot about Napa. All the other parts stores don't carry it, but Napa can get pretty much any hard-to-find part.
Ghettobird52
Jul 5, 2024 11:18 PM
Casey Meyers
Mar 2, 2016 10:46 AM
69 Six Pack
Oct 5, 2015 07:51 PM
BurlyChev
Aug 16, 2015 09:08 PM
Mister_Johnny99
Interior Parts Wanted
Aug 14, 2015 12:59 PM
