Where is my oil going???
Old Sep 11, 2001 | 06:49 PM
bhaas's Avatar
I'm going thru about a quart every week or so. Fresh rebuild, I checked all the plugs and none are wet. It doesn't smoke or leak anywhere. I'm stuck on this one. Help. Thanks.
Brad...
1986 SC Camaro
Mods: Threw 2.8 in garbage, put in rebuilt
350 .060 over, XE268H Comp cam, Edlebrock
Performer Intake and Edlebrock 600 CFM Carb,
Pete Jackson noisy GearDrive (which sounded
cool for about 5 minutes, now I'm sick of it)
Rebuilt TH350, 3.42 Rear Gears. LCA RLB's.
B&M Mega Shifter.
Soon to be T5 YES!!!
Old Sep 11, 2001 | 07:14 PM
ede's Avatar
ede
if it is new rebuild the rings may not have seated
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Sep 11, 2001 | 07:15 PM
rezinn's Avatar
Is your coolant overflowing? I had a customer tell me that his oil was "evaporating" once, and after I got him to change to mobil 1 it no longer happened.
Old Sep 12, 2001 | 09:49 AM
bhaas's Avatar
It's a pretty new motor. I got about 4000 miles on it maybe. I'll give the Mobil One a try. how long does it take for rings to seat? I wouldn't think it would take 4000 miles to seat. Thanks for the help.
Old Sep 12, 2001 | 02:23 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
How many miles does it take to use up a quart? I had a rebuilt 350 in the '57 that used a quart every 400-500 miles and it did not smoke or foul the plugs. I finally determined the .030 cylinders had .040 oil control rings on it (.060 gap!).
If the rings have not seated, Mobil 1 isn't going to help that situation - Bon Ami would, though. But, by 4000 miles, they're either seated or they never will.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Sep 12, 2001 | 04:34 PM
bhaas's Avatar
What is Bon Ami? Isn't that a powder cleaner like Comet? Well if it's not smoking, and my plugs are dry then what's the deal? I go thru a quart about every couple hundred miles or so. It seems to go pretty quick. If I do a compression check on it. What should the pressure be in the cylinders? And what's a safe difference in pressure between cylinders, cause I know they all won't read the same I'm sure. Thanks.
Old Sep 13, 2001 | 01:41 PM
five7kid's Avatar
I had good compression (for a dished-piston engine), about 135. The compression rings were the correct size, only the oil control were wrong.
Do the check and see what you've got.
Oil can also come in around the intake port gaskets. Was anything decked/shaved?
Bon Ami is a cleaning powder. Very fine. Old circle track racer's trick to break the engine in quick after a rebuild before racing it. My point was just that synthetic oil will reduce wear, and therefore reduce ring break-in (if that's your problem, which it probably isn't).
[This message has been edited by five7kid (edited September 13, 2001).]
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
