Porting the Dart Iron Eagles?
Old Sep 13, 2001 | 10:48 AM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
I have a set of Dart 180's that I am planning on porting. I have seen the Standard Abrasives web site, but I also realize that porting techniques are typically head specific. Can anyone give a walkthrough of problem areas and other areas of restriction that could be cleared up in the dart 180's?
355 c.i.
Dart 180 Heads
Lunati 224/224 cam
Harland Sharp 1.5 rockers
Performer RPM Manifold
Holley 600 cfm double pumper
Hooker Super Competition Headers
Flowmaster Exhaust
Competition Engineering Sub-frame connectors
Super T-10
GM posi 3.42 rear
Hurst Roll Control
13.9@102
Old Sep 13, 2001 | 02:35 PM
Damon's Avatar
THere's not much left to do around the valve seats. Dart did a good job with them. Just blend all the sharp edges where the CNC-machined parts of the port (near the seats) meets the base cast parts of the ports. That's about all you can do to them without getting seriously involved. Dart did a good job getting the most critical flow areas right- 1/2" before and after the valve seats.
You could probably smooth out the areas around the valve guides a little, too, but they aren't that bad to begin with.
Backcutting the valves is also a good way to gain some flow once you have determined the exact relationship between the valve and it's seat.
[This message has been edited by Damon (edited September 13, 2001).]
Old Sep 13, 2001 | 03:11 PM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Well, there is definitly room for improvement. Dart heads flow something like 208 cfm at .400'' and 209 at .500''.I'd be happy with about 10% cfm improvement on the intake and exhaust. If there are any flowbench numbers, before and after porting that someone could post, that would be great. Pictures would also be excellent.
Old Sep 13, 2001 | 03:26 PM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
sammy52401
Nov 11, 2015 07:20 PM
Reid Fleming
Oct 10, 2015 09:56 PM
bplessy
Sep 30, 2015 12:14 PM
mfp189
Sep 27, 2015 09:25 AM
