Is this a BAD place to put a fuel pump?
Old Jul 1, 2005 | 04:57 PM
gtaeric's Avatar
Car: '88
Engine: 305tpi
Transmission: t-5
Well, I'm trying to find a good place to mount my Carter electric fuel pump under my T/A. The only spot that looks like an easy place to mount the bracket is on the torque arm. Would this be a bad idea? Or would it work alright? Where have you guys put yours?
Old Jul 1, 2005 | 07:09 PM
gtaeric's Avatar
Car: '88
Engine: 305tpi
Transmission: t-5
well, in the instructions it says not to mount it more than 24" above the fuel pickup. On these cars that means almost anywhere except the roof LOL. So would I be ok mounting it in my engine compartment? Maybe where my old air box used to be? I know that electric pumps are nice because they are pushers instead of pullers, but I'm not looking to get anything crazy for power, so I think I would be ok in that aspect.
Old Jul 1, 2005 | 08:11 PM
badazz84camaro's Avatar
u want the pump as close to the gas tank as possible, try mounting it to the flat area in front of the axle, where the back of the rear seat rests, that is a perfect spot because that is where all the fuel lines connect from the sending unit in the tank to the rest of the lines.
Old Jul 3, 2005 | 03:07 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
here is where I mounted mine,
Old Jul 3, 2005 | 05:37 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
When I bought my car, a carter street pump was mounted right where that filter or whatever that is beside the pump in the above picture. Maybe a little bit lower.
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Jae992
Aug 27, 2015 09:07 AM
92camaroJoe
Aug 13, 2015 06:07 AM
