350 with a T5 tranny..big problem
Old Sep 16, 2001 | 07:26 PM
blackZ28's Avatar
Me and my cousin are dropping a 350 small block into my 82 Z28. It has a manuel T5 transmission which is tilted at 18 degrees. One big problem though....we cant find a compatable starter for the project. we need a starter with an offset bolt patern but also enough clearance from the nose of the starter to the top of the starter. we tried many different GM starters and have not come across one like this but there must be one out there.
I know there must be someone who has done this same project and has had the same problem as we do because the T5 is a very popular tranny upgrade in 3rd gens and the 350 is also a very popular upgrade so there must be many people out there who have had this same problem. any help and/or part# would be appreciated. thanks.
Old Sep 16, 2001 | 07:58 PM
cvpde37's Avatar
I must be missing something here. A T5 is not an upgrade for a thirdgen, it was a factory option. I put a '72 350 in my 84 and used the flywheel and starter from the original 305 with no problems.
1984 Z28 350
Never argue with an idiot, they'll just bring you down to their level and beat you with experience
My Web Page
Old Sep 16, 2001 | 08:12 PM
blackZ28's Avatar
we're trying to put a '69 350 in, we used the flywheel off of my 305 and were gonna use my old starter but its not fitting. the 305 was a straight bolt starter and we need an offset for the 350 but we cant find one with the right amount of clearance.
Old Sep 16, 2001 | 08:17 PM
zroc's Avatar
Car: 87 IROC
Engine: LB9 for the moment
in an 82 a t-5 would be an upgrade as they were not available til' 83...
zroc
Old Sep 16, 2001 | 10:12 PM
87RS402's Avatar
<font face="Verdana, Arial" size="2">Originally posted by blackZ28:
...we need an offset for the 350 but we cant find one ...</font>
And you most likely won't. At least one that will work with the combination.
https://www.thirdgen.org/messgboard/...ML/002835.html
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Jonas Earl
Sep 27, 2015 07:39 AM
monte87cortez
Sep 26, 2015 08:10 PM
88rscamar0
Sep 23, 2015 09:08 PM
