TPI shooting way too much fuel
Old Sep 19, 2001 | 05:47 PM
TinMan's Avatar
I'm needing some help on a problem I have with my 86 TrnsAm.It has a 305 V8 TPI enjected..Let me start at the beginning..I was cruising to work..when i felt like i hit a pothole...and my car just died..never had this prob before..I coasted to a closed gas station.Put it back in Park..and then tried to restart my car..it just cranked..but wouldn't start..it did sound different than usual..when starting.First i thought it wasn't getting no spark..as if my coil went out..but it is..I pulled one of the spark plugs out and checked it..was covered in gas..dripping..I had a friend crank my car with..the one spark plug out..and Gas just squirted out up my Forearm...I'm no mechanic..but i thought Gas is just to spray a light mist into the chamber..I had the car towed to a friend's House..he is a certifide Mechanic..works for the City as a mechanic..He thought it was the computer chip..we replaced it with a new one..but..still won't start..keeps flooding with fuel...I did have a busted motor mount..which i thought might be the reason why i have this prob...i have fixed the motor mount..but I'm guessing..that i might have nocked something loose..that has something to do with my TPI..I was accelerating..when i felt what seemed like a pothole..when it just died..So..if anybody has any ideas..they can give me..PLEASE REPLY..I do miss my TransAM..Badly..now its just sitting pretty..
Old Sep 19, 2001 | 06:05 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Wow...welcoome to thirdgen.org.
Seems if you have that much fuel in the cylinders, it must just be dmping in from somewhere...
A few possible causes could be the fuel regulator has ruptured or an injector(s) are stuck open (which leads to several "how come's"). The cold start valve could be open as well.
Frozer!!!
Jan 19, 2024 04:55 PM
NBrehm
Aug 25, 2015 11:49 PM
beachrodder
Aug 25, 2015 08:05 AM
R3500
Aug 17, 2015 12:16 PM
Sanjay
Aug 12, 2015 03:41 PM
