fuel pump swap question
Old Jul 11, 2005 | 12:54 AM
Borsty's Avatar
Car: 89 Trans am
Engine: TBI 350 HO Vortec heads
do u really have to drop the rearend?????
it looks like u can slide it out.
Old Jul 11, 2005 | 02:19 AM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
yep. Drop the rear or cut a hole above your fuel tank. I'd recommend dropping the rear unless you're REAL good with a sawzall.
You'll have to drop the exhaust too.
Old Jul 11, 2005 | 02:49 AM
Borsty's Avatar
Car: 89 Trans am
my car doesnt have exhast at this time, would that make it possible to wiggle out without dropping the rear?
like it seems it i jack it up and put jackstands under the frame so the suspension is fully relaxed i should easily be able to slide it out.
Old Jul 11, 2005 | 11:15 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
no possible way...learned the hard way you have to drop it....auuugggh...it sux.or pay about $400 to have it done...sux too
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
