fuel pump tech., help me out!!!
Old Sep 20, 2001 | 06:55 PM
j166a99's Avatar
scenario:
one morning i start my bird (warmup) and car just dies. tried starting again and no luck, crank wont catch at all.
troubleshooting facts so far:
**2 problems**
1) tested wires underneath rear seats and only getting .025 volts when ignition on. looked at schematics and supposed to be getting 12v drive from ECM (the ECM?!?!?,awww man. dont tell me that...)
2) bypassed 4 wire relay and and jumped outer wires to complete circuit (what the relay is basically supposed to do when ingition on) and gettin 12v now, but pump no turn on (damn, pumps gone.)
so basically step #2 i was able to determine that the pump is out of commission. but step #1 is where i am stuck. could it be the ECM? is this a known issue? maybe something else?
any suggestions are appreciated...
thanks in advance! -john
'86WS7
Ram Air...
*EiyseWhite*
Old Sep 20, 2001 | 10:23 PM
Vader's Avatar
John,
Between the ECM and the fuel pump is a relay. It's most likely the problem, not the ECM.
As for the wiring under the rear seat, you might be better off checking the wiring near the fuel pump itself, so you can also check the ground continuity.
Later,
Vader
Justice and Freedom will Prevail
Old Sep 20, 2001 | 10:25 PM
Vader's Avatar
It's a little like this:
Later,
Vader
Old Sep 21, 2001 | 05:13 PM
j166a99's Avatar
thanks VADER!!!, im gonna work on it this weekend. hopefully i'll get it up, but i'm a bit more confident now with you schematic.
thanks dude...!
'86WS7
Ram Air...
*EiyseWhite*
Old Sep 23, 2001 | 03:27 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
You could try running a wire straight from the battery to the connection in the back, and run a ground wire too and see if it kicks on if all else fails. Could be a wiring problem and it's an easy check before dropping the tank.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
