starting problem and rough idle in 86 TA. please help!
Old Sep 23, 2001 | 02:40 PM
kernel's Avatar
when i go to start the car in the morning, after it has been sitting all night, it will start up but then die out or it will idle really low and rev itself up. it seems like it is ididling low too after i am driving (like 500-600 rpms). when i press on the gas really lightly it will feel stumbly and sound and feel like it is missing or something. i had it checked for codes and we got a 44 which i was told means a lean exhaust. do u think that has anything to do with the way it is running. what should i look into fixing. fuel filter?02 sensor? IAC,TPS? or is there like a huge leak somewhere? i already have done everything in the sig so i have ruled igniton out. please help.
1986 WS6 pontiac trans am
5.0 305 TPI V8
700R4 tranny w/transgo shift kit. borg warner wires,accel cap and rotr,delco plugs, K&N
KYB shocks,dynomax high flow cat,3"intermediate pipe,40 series flowmaster
w/2 3" tailpipes.
"ponys can run but birds can fly"
www.community.webshots.com/user/kernel20
Old Sep 23, 2001 | 10:48 PM
RS91's Avatar
I had this similar problem... Try looking for any vacume leak, clean your IAC with carburator cleaner. If this does not solve your problem, Check your O2 sensor if it is carboned up then try replacing it. Mostlikely it could be your O2 sensor...
Old Sep 24, 2001 | 10:41 AM
Kyle F's Avatar
I had a similar problem to. My solution was that the Idle needed adjusted with the Throttle stop screw.
That was a tremporary fix what ended up happening was the IAC was open too far and was not adjust properly. When it finaly failed I had to put a new one in. Did the reset procedure for adjusting Idle and what not. then Adjusted the TPS to the proper readings and ran perfectly afterward.
89 Trans Am Turbo 3.8L All stock 43,000 miles #1053 of 1555
Past Thirdgen:
86 Trans Am w/ built 355TPI with SLP goodies and too much other stuff to List. One sweet *** car, wish I would have had a good enough Job to pay insurance on three cars so I could keep it, but for a 89 Turbo Trans Am w/ Low miles, I think I made the right choice!
92camaroJoe
Jul 29, 2023 07:57 PM
backtothe80s
Sep 5, 2015 12:39 AM
BurlyChev
Aug 16, 2015 09:08 PM
92camaroJoe
Aug 13, 2015 06:07 AM
