CODE 32 - questions
Old Sep 26, 2001 | 04:46 AM
TMoNeE's Avatar
Car: 87 Z28
CODE 32 - questions
Hey.. when i drive in 4th gear for a long time my service engine light comes on... check the code... code 32... is it bad to drive with it even tho its just EGR...
Old Sep 26, 2001 | 06:06 AM
Vader's Avatar
T,
It isn't bad to drive with a faulty EGR, but it would be better to have a functioning one. You're not going to cause any engine damage.
The tree-huggers will tell you that you're spewing more nitrous oxides (which you are) but the rest of us will remimnd you that you're probably running hotter combustion chambers, and that the ECM will be retarding spark to compensate, which can mean less power for you. Eventually, you should look into repairing it.
Later,
Vader
Justice and Freedom will Prevail
chazman
Aug 28, 2018 03:25 PM
CORV3TT3
Aug 23, 2015 11:26 AM
chazman
Aug 22, 2015 02:01 PM
redmaroz
Aug 16, 2015 11:40 PM
