What would you Do?
Old Jul 22, 2005 | 11:25 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
What would you Do?
This is not a whats the best oil question? I need some suggestions.
I have a 305 I pulled from a t/a going in my 88 firebird this weekend. This is not permanent, I plan on getting a 350 eventually in a year or so.
While its out would you buy a gasket set and replace all the gaskets? Or let it hang in there for a year.
Also Would you run reg, syn blen or full syn oil?
This engine has to be reliable for now.
I have some other questions too.
The 305 i pulled has a mech fuel pump on the side.
This is a four bar carb, Do I have to drop the tank and disconnect the electric fuel pump or can I just cut the wires and leave it in there and run the mech pump?
Also the 83 t/a has rear disc brakes. Yes I know the rear brake fittings do not fit the 88, so how do i make them fit?
thanks
Old Jul 22, 2005 | 11:30 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
If the "new" engine has obvious leads. Fix 'em.
Just run dino oil.
If the car was originally tbi, get a regulator, and use the intank pump, if it was tpi, get a regulator with a return line.
a tune-up would not hurt either.....
Not sure about the rear.
