advice on upgrades for an 86-87 monte ss
Subscribe
Sep 27, 2001 | 12:48 PM
ok I know again this might not be the right place for this but a lot of you seem to be very knowledgeable on this board..
a friend of mine wants to buy an 86 or 87 monte carlo ss.. apparently they came with a 305 using a c3 carb setup which is computer controlled. they have the air pump and egr and all that crap.. the trick is he wants to either upgrade cam, heads ,intake etc, or swap the engine.. he wants to keep it 100% emission safe. anyone have any ideas or know of anyone that has done this??
thanks..
'88 C1500 350 TBI
Belltech 2/4 Drop,
Nitro Drop Shocks,
3.73 Rear gear ratio,
Edelbrock performer TBI intake, performer cam, timing chain,
Hiflow cat with Rhino dual 2 1/2" out the rear. American Racing Neptune 16x8 wheels with Kumho 712's, 255-50 series
Reply 0
Sep 27, 2001 | 01:04 PM
The motor is basically the same as the F car L69. It responds to all the same mods the same way. His first mod should be a good set of application-specific headers such as Edelbrock TES; then a cam, such as a Comp XE262H; then heads.
My late little brother had a 87 MC SS, his was not a roller motor. I do not know for sure if that is typical or not but I suspect that it is.
https://www.thirdgen.org/messgboard/...ML/012689.html
Here's the kind of results he might get... in this case, this motor went from 190 HP to about 265 HP, with similar mods, retaining compliance with California emissions.
ICON Motorsports
Reply 0
Sep 27, 2001 | 02:09 PM
RB is on the money...
Exhaust (Headers/CatBack) will wake that thing up!
Don't go crazy on the cam(too radical) and heads and it should remain emissions legal while putting out decent power.
Finally, the key is to have ittuned properly not only to put out max power, but to have optimal(low) emissions.
1989 Chevrolet Camaro IROC-Z
L98 - 350c.i. TPI, rebuilt 700R4 auto w/shift kit, Dual catalyst Monza PaceSetter Cat-Back, SLP 1 5/8 Coated Headers, 3.23 Posi rear, Hypertech chip with 160stat, MSD 6A, Under-Drive pulleys, AFPR, K&N's, !Air Box w/ Ram Air, moddified MAF, !TB Coolant, Spohn Dual Cat SubFrame Connectors, Alarm, Keyless entry, remote starter, 92 Z28 AeroWing, Brand New Paint (6/21/01)
Future: ZZ4 TPI w/EGR, T56, 3.42 or 3.73, Spohn strut tower brace and LCA's, Accell 24# injectors
1989 Chevrolet Celebrity Eurosport <--DEAD AS OF 9/20/01
2.8 MPFI, no mods
225,000 miles and still ticking!
More info and pics on my webpage:http://go.to/iroc-z
AOL IMer: GPA 0point0
Reply 0
Subscribe
