Fuel Pump Help
Old Jul 23, 2005 | 08:22 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Fuel Pump Help
1992 RS - Swapped in carbed 350. Removed ECM and all sensors except coolant sensor for guage and oil pressure sending unit. Using in-tank stock fuel pump with return-style regulator. When I connect battery, fuel pump runs constantly, whether key on or off.
How do I get proper fuel pump operation with ECM removed?
Old Jul 23, 2005 | 02:48 PM
POS350Z's Avatar
Car: 89 Iroc
Engine: L9-to small
Transmission: 6 spd
...one of my friends who did a V6 to V8 swap used a switch in the car to turn on the FP....
350Z
Old Jul 23, 2005 | 03:06 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
That would be the simplest route, wire in a new circuit solely for the fuel pump.
wire from ign hot source with a fuse to a toggle switch. From the toggle switch into a relay then from realy to the fuel pump. For added safety you could wire in a low oil pressure safety switch that will kill power to the fuel pump if oil psi gets below a certain point should the motor take a crap on you or if you get into a wreck.
Old Jul 23, 2005 | 05:16 PM
Car: 1992 RS
Engine: Carbed 350
Problem found!
Problem found! Oil pressure sending unit bad - giving positive pressure reading always, enabling fuel pump always. Weird that the relay doesn't do anything - I unplugged relay and fuel pump still ran - until I put new OPSU in. Looked at schematics - fuel pump gets a hot always feed directly from battery through OPSU.
This would also explain the dead battery after 2-3 days of not running the car - fuel pump always on draining battery. Can't hear the in-tank pump in the street, with traffic, neighbors lawn mower, dogs barking, and various other daily noises one faces in the driveway. So, if anyone ever has a battery always dead after 2-3 days, check fuel pump for noise with ignition off in a quiet spot. Lesson learned - ALWAYS have a house with a quiet garage!
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
