Car won't crank, but makes a noise..PLEASE HELP
Old Sep 28, 2001 | 07:39 PM
87firebird's Avatar
My car will run just fine then when I shut it off, sometimes it wont start. It wont do anything. It makes a noise in the rear almost like an in-tank fuel pump, but I have a mechanical and it also makes a click in the drivers front of the engine, right beside the firewall(by the wires) I cant figure it out. What could it be. The starter works fine because I started it from the battery and it worked fine. I had the same problem awile back and I found a switch by my fuse panel that will not allow you to start it if it is switched off. I switched that and it started right up. But now I switched it back and forth a bunch of times and it still wont start, but it just makes those 2 noises. PLEASE HELP. I NEED IT TO DRIVE AND I CAN'T..
  • 87 firebird formula
  • 305, 4bbl
  • Edelbrock intake
  • Holley 600 double pp
  • MTX 4250D amp
  • 2-MTX 6000 10"
  • white with red int.
  • Pioneer cd player
  • a/c
  • power windows and locks
Old Sep 28, 2001 | 07:46 PM
firbird's Avatar
try tapping the starter and make sure you dont hit it to hard and break it my starter did that a few days ago and i was stuck tried taking every thing apart to look for the problem then i just got under there and tapped it (the Solenoid) and it worked just fine and turned over, give it a try
,danny
Old Sep 28, 2001 | 07:56 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
<font face="Verdana, Arial" size="2">Originally posted by 87firebird:
...It makes a noise in the rear almost like an in-tank fuel pump...and it also makes a click in the drivers front of the engine, right beside the firewall(by the wires)...MTX 4250D amp
</font>
Check your grounds, both system and especially engine.
"Question with boldness even the existence of a *** ; because, if there be one, he must more approve of the homage of reason, than that of blind-folded fear."
-Thomas Jefferson
Old Sep 29, 2001 | 01:26 PM
Polarsmurf's Avatar
had same problem... 180$ later, new starter.
1989 firebird formula
Old Sep 30, 2001 | 05:47 PM
87firebird's Avatar
Yup, It was my starter. Changed it today. That wasn't to fun.
  • 305, 4bbl
  • Edelbrock intake
  • MTX 4250D amp
  • 2-MTX 6000 10"
  • Pioneer cd player
  • a/c
Reborn756
Sep 4, 2015 03:42 AM
TheExaminer
Aug 26, 2015 04:59 PM
mizz0313
Aug 12, 2015 06:45 AM
BrianI
Aug 9, 2015 11:52 AM
z28addict8490
Aug 7, 2015 08:48 PM
