Wherez me fuel pump, can I replace it myself
I've got an LO3 1989 Camaro RS with 305 v8, is the fuel pump inside or outside the tank and can I change it myself if its outside?? If its outside where should i start looking.
I believe that the stock pump can barely even keep up with a stock 305.
un4givin89
1989 Camaro Ralley Sport
305 TBI
Edelbrock Open Element
1 1/2 lowering springs
Hooker Shorty Headers
Str8 3inch Pipes No Cat
Flowmaster series 40 muffler with dual outlet.
www.mikekey.net
un4givin89
305 TBI
www.mikekey.net
<font face="Verdana, Arial" size="2">Originally posted by 85SportCoupeto89RS:
The fuel pump is in the tank.I think you have to drop the rearend and lower the tank to get the fuel pump out.</font>
Hopefully i can get a definite answer out of this....but when you say "drop the rearend" are you saying to just let it hang freely or do you actually have to unbolt the shocks?
Reason I ask is because i saw some doods trying to remove a gas tank from a thirdgen and the rearend was just hanging freely. They were trying to wedge the tank between the axle and trunk/bumper and it was a very tight squeeze. I never saw if they got it out but they were having a hell of a time trying.
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
-Currently collecting parts for T5 swap
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
Welp, i just did this recently. When he said drop the rearend he meant totally. Shocks and all. If you just lower the rear the edge of the tank will just hit the houseing and tick you off even more. Then you have to wiggle and giggle the fillup "hose" out. This i found to be the hardest part as it has bends and such. It took me about 12 hours to do. With another person helping. But note that i ran into problems with the "trackbar (some call it the panhard)" So expect to run into things that don't want to come off.
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Gutted cat
-!AIR
-Gutted Air Boxes
89 IROC-Z 350 TPI
-Flowmaster Catback
-K&N Airfilters
-Ported Plenum
-Gutted cat
-!AIR
-Gutted Air Boxes
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
With all that down time, danger (you know, GAS), and labor involved, I had a local shop do it. It cost me $130 (labor only), but if anything went wrong later, which it did, then they had to fix it free cause they did it wrong, not me.
All that went wrong is one of the panhard bolts wasn't tight, and made a lot of jiggling noise. But if it would've snapped, then they would've been the ones liable, not me.
Sometimes it pays to pay.
AJ
92 RS w/t-tops 305 TBI Auto.
170K miles and don't burn a drop o'oil
-K&N Truck filter #1500 w, open ele.
air cleaner
-Dynomax 2 1/2" cat-back
-B&M TransPak
-Jet Stage2 Chip
-180* T-Stat w/ 185* Fan Switch
-JVC CD--Alpine speakers & 4ch. amp
Rockford Punch 100. 1 - MTX 12" sub
AJ
air cleaner
-B&M TransPak
-Jet Stage2 Chip
Car: 89 Camaro RS
Engine: 305 TBI
I changed the pump in my 89rs, with out totally removing the tank, I just raised the body as high as the brake lines would allow, and dropped the axle as far as the brake lines would allow. and tilted the tank downward so the lowest point was was the right side of the car, and there was enough room for me to get in between the tank and the body, of course I removed the shocks & springs, and pulled aside the exhaust system.
It was the most PITA job I've ever done on this car. But it only cost me 60 bucks Canadian for the pump (carter), if I took it to a show they where gonna charge me 500 bucks.. I don't think so..
89 RS Camaro, LO3 305 TBI
Autometer Air/Fuel Ratio Guage
Cooling Fan Overide Switch
L69 Duel Snorkel Intake
Dynomax Ultra Flo SS Cat Back
Axle/Gears: 3.45, 3.27, 3.27
<font face="Verdana, Arial" size="2">Originally posted by FastElectrics:
</font>
</font>
90 RS Convertible
Owner: Top-Down Solutions
(626)369-0040
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
92camaroJoe
Aug 13, 2015 06:07 AM
