Elongating bolt hole on TPI? and fitting earlier heads?
Old Oct 1, 2001 | 10:49 AM
Damage's Avatar
I just learned that by elongating the center bolt holes on my TPI ('88 L98) that I can fit earlier model heads to my engine.What is the best way to do this and are there any other mods that need to be done?
Thanks for your time and effort,
Denne (cycobeast@yahoo.com)
Old Oct 1, 2001 | 03:21 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
A machine shop would probably be the best way to go. They should do it pretty cheap, and that way you know it won't get screwed up (hopefully). Older style heads will also require you to get different valve covers, as centerbolts won't work.
91 Z28
Come see The Vicious...
Old Oct 1, 2001 | 06:33 PM
Mike89GTA's Avatar
It's easy, I just used a dremel.. if you take your time you can't really mess up.
Jeremys87
Jul 14, 2022 09:08 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Reddeath210
Oct 6, 2015 08:20 AM
Sanjay
Aug 12, 2015 03:41 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
