1.6 rockers on the exhaust
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
hello- i've got a idea and thought i'd run it buy to see if anybody has tried it or has any thoughts. i've got a single pattern cam,comp 294s, and i've been thinking about adding 1.6 rockers to the exhaust side to help crutch the exhaust system we are sadled with on these cars.i've tried different exhausts and have had clearence problems or run ins with the police.what i want is a quiet car that can still run.the numbers. i've got hedman headers with a single 3" exhaust now. any inputs?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It used to be more done more often before dual pattern cams were commonly available. I don't think it will make up for an inadequate exhaust system though, opening the valve more won't help if there's nowhere for the exhaust to go.
You don't take Metamucil because your toilet flushes too slow.
Car: 86 camaro
its not that i don't have an exhaust ,i just thought the extra lift and duration would give more time for the exhaust to leave.its done on the intake to help overcome weak cylinder heads , why wouldn't it help scavenge a restrictive exhaust?
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
