What are the different sensors?
Old Oct 1, 2001 | 11:16 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Transmission: TH700R4
Im currently swapping a lot of parts on my '86 305TPI, and during the teardown I've found a lot of sensors around the engine - but Im not confident which one is what, could someone help me out some?
1. Drivers side head (water temp?)
2. Pass. side by starter (knock sensor?)
3. Front of intake, small
4. Front of intake bigger
5. On top of intake (under plenum) near the center
I'd appreciate inputs on which is what, and also if any/all of these should be replaced while I have them out anyways.
Thanks a lot!
Ken
1986 IROC-Z Conv't
17x9.5 TT II's w/ 275/40x17's, BMR stb, Lakewood APR, Jamex 1.5" Lowering Springs
ChevyKen's Cars
Administrator @ ChevyWorld.net
Old Oct 1, 2001 | 11:32 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
<font face="Verdana, Arial" size="2">Originally posted by ChevyKen:
Yep, for the temp gauge.
Hmmn, my KS is hidden between the block and the control arm, kinda under the 4 and 6 plugs, IIRC.
Ones the CTS (for the ECM) other is the ColdStart valve sensor. I've an '89, so can't tell ya which is which for sure, and my '87 intake is buried in the shop.
I'm thinking the EGR temp sensor.
Thanks a lot!
Ken
</font>
Probably a good time to replace the EGR stuff (solenoid, valve, sensor), everything else you can easily get to later, if needed.
[This message has been edited by 8Mike9 (edited October 01, 2001).]
Old Oct 2, 2001 | 12:09 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
#5 Is The MAT Sensor. Manifold Air Temperture Sensor.
86',88',89' IROC-Z, 350 TPI, 700-R4
94' Formula, LT1, 6spd
Old Oct 2, 2001 | 12:23 AM
camaroguy99's Avatar
#5 is probably the EGR or the EGR temp sensor. He said it was on the intake under the plenum not on the plenum.
Old Oct 2, 2001 | 07:13 PM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
Thanks a lot!
Ken
</font>
1. Water temp sensor for the gauge, NOT the ECM
2. Knock sensor, (near the oil pan rail?)
3. Front of intake, small = CTS, Coolant temperature sensor for the ECM
4. Front of intake bigger = Cold Start injector sensor/timer NOT for the ECM but to a power wire, then to the 9th injector between the tubes on the drivers side.
5. On top of intake (under plenum) near the center = One wire = EGR temperature sensor, two wires plugged upside down = MAT Manifold temperature sensor.
That's my *guesses* Hope this helps.
_ ___ _
SMasterson
Old Oct 2, 2001 | 08:11 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Thanks a lot guys!!!
I sure appreciate your help!
Ken
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
