Pick up in a distributor..
Old Oct 2, 2001 | 02:08 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Can you replace them or not? If ya can replace them how?
Kat
Old Oct 2, 2001 | 03:03 PM
Guest
Guest
Posts: n/a
Of course you can replace it. You have to take the gear off the bottom, pull the dist. shaft, and then theres a clip you will have to break to get to the pickup on the 88-up, I havent been in the earlier ones in so long I cant remember if it has the same sorta clip but it probably does.
Old Oct 2, 2001 | 04:04 PM
Biochem's Avatar
Car: 2002 SOM z28
There is a pressed in pin that you need to pop out of the gear to get it off, but the rest is pretty easy... at least on pre-88 HEIs
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Oct 2, 2001 | 05:31 PM
Bjase's Avatar
Car: 88 IROC
Just thought I'd mention that the distributor has to come out as the first step.
My car has a pre-88 set up; I didn't have to break any clip to change the pick up.
88 IROC with cobbled together (not by me)drivetrain, 86 (?) TPI unit on an '83 305,CE subframe connectors, Edelbrock strut tower brace, polygraphite bushings all around...it handles like a dream, but man is it hard to push!!
Old Oct 2, 2001 | 10:25 PM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
To replace the pickup.
remove distributor.
With flat punuch, or roll pin punch, remove roll pin. and pull the gear off.
Gently work the shaft out, it's probably nice and scummy.
remove the little snap ring on the top. and the bolts holding it in.
wiggle it off.
It's always SOMETHING
Old Oct 2, 2001 | 11:50 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Cool guys thanks.
I was told before that it was better just to replace the distributor before than to screw with that..
Only reason why I ask is that on my girlfriend 79 Z everthing in the distributor was replace except fer that.. Now the tach is jumping all over the place. Ya know if it isnt one thing it is another lol
Kat
RedLeader289
May 28, 2019 01:47 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
jaridjohn
Oct 5, 2015 07:01 AM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
92projectcamaro
Sep 29, 2015 07:07 PM
