bog/hesitation/near stall
Old Oct 2, 2001 | 03:31 PM
z28onTweenkies's Avatar
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
ive had this problem in the past, but now its becoming more noticeable. basically in gear my car idles at a little over 500 rpm. in park it idles at 750 rpm. when i take off after sitting at a stoplight my car hesistates, and the hesitation gets worse the more i step on it. could this be a spark problem? the plugs and wires are all good, but i am jumping a big spark off of the distributor. i noticed the last time i had the distributor out there was a cut in one of the wires heading the four wire harness plug in. ive had a problem with the car starting and wanting to die soon afterwards. and another thing, my choke isnt hooked up. sorry for the long story
1987 LG4 Camaro z28
Performance
KN airfilter, flowmaster 80 series and catco high flow converter, 180* thermostat, edelbrock performer intake
System
Panasonic CQ-DF200U deck, fosgate speakers (hpc1369, frc2246), fosgate 400a4 amp
Old Oct 2, 2001 | 10:21 PM
Engine: LB9
Axle/Gears: 3:43
anyone?
Old Oct 2, 2001 | 10:31 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
ttt
Old Oct 3, 2001 | 11:43 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
__but i am jumping a big spark off of the distributor__
I think this could be considered a major contributor to your problem.
Check the cap for cracks, make sure all the plug wires are in and secure on the cap. Also make sure they are routed neatly, not laying on top of each other.
If spark is jupming from the cap, it's not getting (completely anyways) to the plugs, where it should be.
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
amcnellis
Sep 16, 2015 04:16 PM
