damage maybe oil pressure??
Old Aug 2, 2005 | 09:35 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
just replace the stock oil pressure sensor. i am not sure if it is the right part but it works. could using the wrong sensore damage anything???? car runs fine, it shows oil pressure a lil under 30psi at idil, is this normal, dont know cuz the orginal one never worked right. the part number is ps-237. can some one help me out??
Old Aug 3, 2005 | 07:51 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Around 30 psi at idle and 45 psi off idle is normal for a warmed up engine.
You'd know if you had the wrong sender because the gauge would be wacky or the electrical connector wouldn't plug in.
89GTAOz
May 16, 2020 09:31 AM
Prodigious
Oct 4, 2015 11:20 PM
solocus
Sep 2, 2015 12:14 PM
CamaroGuy350
Aug 30, 2015 02:56 PM
355sbcTPI
Aug 19, 2015 04:38 PM
